La date/heure actuelle est Ven 26 Avr 2024, 23:27
3 résultats trouvés pour M-8800
Maxlog M-8800 (Mobile)
Fréquences: 25.615-30.105 MHz
Canaux: 360
Modes: AM / FM / SSB / CW
Puissance: 40 W
- Frequency control: PLL
Power supply: 13.8 VDC
Antenna impedance / connector: 50 ohm / SO-239
Other features: PA. NB. Roger beep. +10 KHz button. Channel 9 button.
Dual watch. Scanning.
External speaker connector:
Source: https://www.rigpix.com/cbfreeband/cbfreebandselect.htm
#Maxlog #M-8800
- le Mer 02 Nov 2022, 19:58
- Rechercher dans: Marcom | Maxlog | MegaJet | Mega System | M-Tech
- Sujet: Maxlog M-8800 (Mobile)
- Vues: 1678
K-PO M-8800 (Mobile)
Frequency range: 25.615-30.105 MHz
(5 / 100 Hz / 1 / 10 KHz steps)
Channels: 360
Mode: AM/FM/SSB/CW
Power output: AM/CW: 12 W - FM: 40 W - SSB: 40 W
Voltage: 13.8 VDC +/-10%
Dimensions (W*H*D): 280*60*250 mm
Weight: 2.1 Kg
Manufactured: China, 2013-201x
Other: PA, DW, ANL, NB, ASC. Roger beep. Echo chamber.
Backlit faceplate, SWR-meter, Scanning, PC-programmable
Source USA: http://www.rigpix.com/cbfreeband/cbfreebandselect.htm
(Vidéo: VOYAGE BR-9200 / K-PO M-8800)
#K-PO #M-8800
- le Mar 20 Sep 2016, 18:02
- Rechercher dans: Itam | Jopix | K-PO | Luiton
- Sujet: K-PO M-8800 (Mobile)
- Vues: 1129
(Source de la photo: Facebook Québec)RF Power Output 40W SSB/CW (pep)/ 10W AM (rms)/ 40W FM (rms)
Dual Finals on Heat Sink
Modes AM, FM, USB, LSB,CW
- Product Description
MAXLOG M-8800 10/12 Meter Mobile
GENERAL SPECIFICATIONS
Frequency Coverage: 25.165 to 30.115 Mhz
Antenna Impedance: 50 ohm, unbalanced
Frequency Control: Digital Phase-Lock Loop (PLL) Synthesizer
Frequency Accuracy: Better than +10 ppm from 0 - 40 °C after 15 min. warm up
Power Requirement: 12 -13.8 V DC, negative ground
Current Consumption: 9 amps maximum
Dimensions: 6 x 2 x 9.5 in (W x H x D)
Weight: 2.9 Ibs
TRANSMITTER SPECIFICATIONS
Power Output: SSB/CW/ FM...40+ Watts, ...AM..10 Watts RMS / 40+ Watts PEP
Tuning Steps: 1/10/100hz /1 kHz /10 kHz
Final Transistors: IRF520 MOSFET (x2)
Spurious Emissions: More than 50 dB below peak output power
Carrier Suppression: More than 40 dB below peak output power
Unwanted Sideband: More than 50 dB below peak output (1 kHz tone)
FM Deviation: +/- 5 kHz maximum
Audio Response: More than 30dB below peak output
Frequency Response: 400 to 2800 Hz
Microphone Impedance: , 600 to 1 K ohms
RECEIVER SPECIFICATIONS
Circuit Type: Dual-Conversion Super-heterodyne
Intermediate Frequencies:
1st IF/SSB/CW IF...10.695 MHz
2nd IF...455 kHz
Sensitivity:
SSB...0.25 V at 10 dB S + N/N CW...0.25 V at 10 dB S + N/N
AM...1.0 V at10dBS+N/N
FM...0.3 V at12dBSINAD
Selectivity:
SSB...4.2 kHz (-6 dB) / 8.5 kHz (-60 dB) CW...4.2 kHz (-6 dB) / 8.5 kHz (-60 dB)
AM / FM...6.0 kHz (-6 dB) /18 kHz (-60 dB)
Clarifier Range: full coverage of the radio! in 1hz/10hz/1khz/10khz steps!
Adjacent Channel Rejection: Better than 70 dB
I F Rejection: Better than 85 dB for all frequencies
Frequency Response: 250 to 3000 Hz
Audio Output Power: 2 watts minimum at 10% THD with an 8 ohm load
Audio Output Impedance: 8 ohms
Microprocessor Controlled
6 x 60 memories
Frequency Scan
Variable RF Output Power all modes
7 Digit LCD Frequency Display
Scanning Microphone step in 1/5/10/100khz steps
Night Illuminated Display blue/green led
Surface Mount Technology throughout
Dimensions 2(H) x 6(W) x 9.5(D) in
What's in this package?
- Mobile bracket with screws
- Microphone
- DC cable
- Replacement fuse
- Manual in English language
CertificateCE,ROHS
Manufactor: Maxlog
Source Suisse: http://www.aliexpress.com/
#Maxlog #M-8800
- le Sam 19 Sep 2015, 23:53
- Vues: 1678
Aujourd'hui à 20:28 par 14KM5701
Aujourd'hui à 15:53 par WarGames58
Hier à 22:09 par 14KM5701
Hier à 16:04 par Dundee33
Hier à 10:44 par 14GEF027
Hier à 08:19 par leglaude09
