Firestik FireRing (Coax pour deux antennes, 18' )
La Planète Cibi Francophone :: Le matériel de la Planète Cibi (Récent & nouveaux) :: Accessoires Antennes (HF)
Coax Type: RG-59 (Dual Antennas)
Connection Type: Ring
Product Details: 18' long
Two low-profile, weather-resistant ring connections
Ring can be mounted above or below mounting surface
- FME connectors for easier routing and installation
95% shielding
Stranded center conductor
Polyvinal center for durability
*Does not include two extra-long stud bolts
Compatible with: The ring terminals are compatible with lug-style studs.
Choose this coax if you need a low-profile, weather-resistant setup to install with dual antennas
Achieve a low-profile, weather-resistant coax setup that's easy to install with this Firestik FireRing kit for dual antennas! The ring-style connections are perfectly suited for low-profile and tight installations, as they extend horizontally -- not vertically -- from the mounting surface. They're also significantly more weather-resistant than standard threaded PL-259 connections, which are built primarily from rust-prone metal. The FME (For Mobile Equipment) ends allows the PL-259s to unscrew, making installation, drilling and cable routing MUCH simpler, as the cable head diamater is reduced from 3/4" to 3/8". Built from RG-59 coax, the cable is 95% shielded for improved signal performance and uses a stranded center for increased durability.
- Type de coaxial: RG-59 (deux antennes)
Type de connexion: anneau
Détails du produit: 18 'de long
Deux connexions annulaires discrètes et résistantes aux intempéries
L'anneau peut être monté au-dessus ou au-dessous de la surface de montage
Connecteurs FME pour un routage et une installation plus faciles
Blindage à 95%
Conducteur central toronné
Centre polyvinal pour la durabilité
* Ne comprend pas deux goujons extra-longs
Compatible avec: Les cosses à anneau sont compatibles avec les goujons à oreilles.
Choisissez ce câble coaxial si vous avez besoin d'une configuration discrète et résistante aux intempéries pour installer avec deux antennes
Obtenez une configuration coaxiale discrète et résistante aux intempéries et facile à installer avec ce kit FireRing Firestik pour deux antennes! Les connexions annulaires sont parfaitement adaptées aux installations étroites et étroites, car elles s'étendent horizontalement - et non verticalement - à partir de la surface de montage. Ils sont également beaucoup plus résistants aux intempéries que les raccords filetés PL-259 standard, qui sont construits principalement en métal à tendance rouille. Les extrémités FME (pour équipement mobile) permettent aux PL-259 de se dévisser, rendant l'installation, le perçage et l'acheminement des câbles BEAUCOUP plus simples, car le diamètre de la tête de câble est réduit de 3/4 "à 3/8". Construit à partir du câble coaxial RG-59, le câble est blindé à 95% pour une meilleure performance du signal et utilise un centre toronné pour une durabilité accrue.
#Firestik #FireRing #Coax #antennes
» SOTA: Croix de Saint clair
» SOTA: Tuc de l'Etang
» SOTA: Falconera
» SOTA: Tête d'Ane
