La date/heure actuelle est Dim 28 Avr 2024 - 9:05
1 résultat trouvé pour TS-990SE
Kenwood TS-990SE
(Utilisable sous licence R.A.)HF/50MHz Flagship Base Station
200 watts output from 50V FET Push-pull PA stage
+40dBm Intercept Point RX
Main RX - Down Conversion on all bands
270Hz/500Hz/2.7kHz/6kHz/15kHz Roofing Filters
Sub RX - Down Conversion on 15/20/40/80/160M bands (as TS-590S RX)
500Hz/2.7kHz Roofing Filters
2 x TFT Colour Display screens
3 x DSP Processors
Built-in RTTY/FSK/PSK/QPSK Decoder/Encoder.
4 x SO-239 Antenna sockets plus RCA jacks for RX-only antenna input and external RX out. "Antenna Name" display function for the 4 SO-239 ports
Connectivity:-
10MHz Ref Clock I/O (BNC)
External ATU port
Keyboard In
COM Port (Female 9-pin)
Straight Key
Paddle/external Keyer
2 x USB-A & 1 x USB-B ports
"ACC-2" Data/audio connector
"Remote" linear connector
Analogue Meter Jack 3.5 mm
"DRV" low-level LF drive
Optical SP-DIF I/O
2 x external speaker sockets
DVI-I Dual-link video port
LAN port
Supplied With
- AC Mains Cable
Fuse , 1 x 4A
Instruction Manual , Includes Circuit Diagram
Line Filter
Plugs , 1 x 7-pin DIN
1 x 13-pin DIN
Caractéristiques générales radio amateur
10 MHz Reference I/O Port , Selectable as Off, Input or Output. Impedance = 50Ω. Input level = 0dBm ± 10dB. Output Level = 0dBm
"Band Elimination Filter" , Offers selectable-width notch function (300-1200Hz in 100Hz steps) with selectable attenuation (20 - 80 dB in 20 dB steps)
Built-in Power Supply Switched Mode PSU
Built-in Voice Guide and Recorder Yes. Fully configurable guidance including operating status, SWR, TX power, menus.
Clock , Two clock displays (local/time-zone) plus date. Can be updated from NTP servers via the LAN port
Port communication D-Sub 9 broches
Connectivity 10MHz Ref Clock Oscillator I/O (BNC)
External ATU port
Keypad (3.5 mm jack)
Straight/Paddle Key/External Keyer (6.3mm jack)
Analogue Meter (3.5mm jack)
"DRV" low-level LF drive (RCA)
Optical I/O
2 x external speaker sockets (3.5mm jacks)
LAN port
Connecteur pour syntoniseur d'antenne (ATU) externe Oui
Connector for Remote/Linear Amp Oui
Codeur/décodeur CTCSS , Single-tone and cross-tone functions
Manipulateur CW intégré à mémoires de messages
Connexion de données pour TNC externe
Limiteur de bruit numérique
Digital Optical Ports , Input = 44.1/48kHz 16/24-bit
Output = 48kHz 24-bit
Dimmer Key Yes - for displays and LEDs. 4 dimmer levels
Direct-access Band Buttons , 10 buttons for Amateur bands 1.8 - 50 MHz plus 2 buttons for General Coverage. Up to 5 band-memories per button
Entrée de fréquence directe
"DRV" Low Level Drive Output Terminal , RCA jack - 1 mW output covers 1.8 to 50 MHz bands plus the 135.80-137.70 kHz LF band.
Dual Receive
DSP Devices 3 x Analog Devices Inc SHARC 32-bit DSP chips
for Main IF, Sub IF and Bandscope functions
DX Cluster Tune Function , With compatible external Kenwood transceiver
Firmware Upgradeable via PC
Firmware Upgradeable via USB Port
Clavier en façade
Mode FSK inverse
Headphone Socket with Dual RX Output , Main and sub-Band RX audio can heard either mixed, or separated to the left/right channels
Stabilité en haute fréquence
Touches en façade éclairées
Key Beep Yes - adjustable + OFF
Verrouillage des touches
LAN Port
Loudspeaker Socket Two external loudspeakers can be connected via 2 x 3.5mm mono sockets. Impedance range 4 - 8 ohms
Blocage de l'émission sur le canal mémoire
Canaux mémoires avec affichage alphanumérique 120 Memory Channels
Memory Shift Function
Système de menu pour configuration individuelle , Switchable between CONFIG A and CONFIG B. Can also be saved to USB stick
Microphone Socket 8-pin "Chrome" type
Monitor Function
Fonctions de balayage multiples
Fonction Sourdine
Logiciel de pilotage PC (en option)
Message de mise sous tension
Power-Off Timer Configurable, including Timed Audio Recording
Pre-amplifier , Configurable per band
Pre-selector , Configurable
Touches de fonctions programmables , 2 Front Panel PF keys plus up to 8 external/mic keys
Compatible PSK31
Filtres à pente DSP coupe-haut/coupe-bas pour récepteur
Suppresseur de bruit du récepteur
Filtre éliminateur de bande pour récepteur Oui
Commandable à distance par Internet ARHP-990 Software allows remote operation
Roofing Filter Equipped with 270Hz, 500Hz, 2.7kHz, 6kHz and 15kHz as standard, plus space for optional 6th filter
Screen Saver , Configurable - two styles including 10-character text for callsign, name etc.
Sky Command 2 , With compatible external Kenwood transceiver
Processeur vocal
Sub Receiver , Equivalent to TS-590S main receiver
TFT Colour Display , 2 TFT displays. 7" main display with operating information, Bandscope, Waterfall and touch-screen tuning function plus 3.5" sub display with audio scope, PSK tuning meter etc. Selectable background colours. 4 different styles of S-meter presentation. Sub-display includes X-Y function (FSK) or Vector function (PSK)
Temporisation d'arrêt (anti-bavard)
Affichage transverter Yes - direct entry of transverter frequency
Filtre audio TX
TX Functions Speech Processor (Adjustable In/Out Levels). Changeable TX Filter Bandwidth. TX Audio Monitor. TX DSP Equalizer. VOX (Adjustable Gain and Delay Time settings). MIC Gain Control. CAR Level Setting. Adjustable Power Output.
Egaliseur TX/RX
USB Port , 2 x USB-A for flash drives/keyboard plus 1 x USB-B for PC connectivity
Variable LCD Brightness with Selectable Dimmer , Four configurable settings
Video Display Port , DVI port. Selectable 800x600 or 848x480 resolution
VOX (commande vocale) intégré , Separately configurable for voice (SSB, FM & AM) or Data Mode. Adjustable Gain, Delay and Anti-VOX
Spécifications radio amateur HF
Puissance de sortie HF 200 W SSB/FM/CW/FSK, 50 W AM
Puissance de sortie 50 MHz RF 200 W SSB/FM/CW/FSK, 50 W AM
Sortie minimale 5 watts pour les opérations QRP
A.C. Supply Voltage 220 - 240 V (50/60 Hz)
Impédance d'antenne - 50 ohms
Plage de syntonisation d'antenne (bandes 160 - 6 m) - 16,7 ohms à 150 ohms
Impédance de la sortie audio - 8 ohms
Puissance audio More than 1,5 W (8 Ohm, 10% distortion)
Continuous RX: 30 kHz - 60 MHz , Within spec - 0.13 - 30 MHz & 50 - 54 MHz
Consommation de courant (environ) TX - 840 VA Power Consumption
RX - 200 VA Power Consumption
Stabilité en fréquence ± 0.1 ppm 0 °C to +50 °C
Impédance du microphone - 600 ohms
Modes A1A (CW), A3E (AM), J3E (SSB), F3E (FM), F1B (FSK) & G1B (PSK)
Notch Filter Attenuation Auto Mode - More than 60 dB
Manual Mode - More than 70 dB
Température de fonctionnement -0 °C to + 50 °C
Elimination des battements du récepteur Supérieur à 40 dB
Circuits du récepteur Main RX - Double superheterodyne
Sub RX1 Down Conversion - Double superheterodyne
Sub RX2 Up Conversion - Triple superheterodyne
Plage de fréquence du récepteur VFO Coverage = 30kHz - 60MHz
Main Band spec guaranteed = 0.13 - 30MHz/50-54MHz
Réjection FI du récepteur Less than 70dB
Réjection fréquence image du récepteur HF - Less than 70dB
50MHz - Less than 60dB
Fréquences intermédiaires du récepteur Main RX - 1st IF 8.248 MHz/2nd IF 24 kHz (FM - 455 kHz)
Sub RX1 Down Conversion - 1st IF 11.374 MHz/2nd IF 24 kHz
Sub RX2 Up Conversion - 1st IF 73.095 MHz/2nd IF 10.695 MHz/3rd IF 24 kHz (FM - 455 kHz)
Sélectivité du récepteur SSB (LO:200/HI:2800 Hz) - More than 2.4 kHz @ -6 dB/Less than 4.4 kHz @ -60dB
CW/FSK/PSK (Width: 500 Hz): More than 500 Hz @ -6 dB/Less than 1.2 kHz @ - 60 dB
AM (LO:100/HI:3000 Hz) - More than 6 kHz @ -6 dB/Less than 12 kHz @ -60dB
FM - More than 12 kHz @ -6 dB/Less than 25 kHz @ -50dB
Receiver Sensitivity - 0.13 - 0.522 MHz SSB/CW/FSK/PSK = less than 0.5µV
AM = less than 6.3µV
Receiver Sensitivity - 0.522 - 1.705 MHz SSB/CW/FSK/PSK = less than 4µV
AM = less than 32µV
Sensibilité du récepteur - 1,705 à 24,5 MHz SSB/CW/FSK/PSK = less than 0.2µV
AM = less than 2µV
Sensibilité du récepteur - 24,5 à 30 MHz SSB/CW/FSK/PSK = less than 0.13µV
AM = less than 1.3µV
Sensibilité du récepteur - 28 à 30 MHz (FM) Less than 0.22µV
Sensibilité du récepteur - 50 à 54 MHz SSB/CW/FSK/PSK = less than 0.13µV
FM = less than 0.22µV
Plage de fréquence RIT ± 9,999 kHz
Suppression de porteuse de l'émetteur Less than -60 dB
Réponse en fréquence de l'émetteur 300 Hz - 2700 Hz (within -6 dB)
Modulation de l'émetteur SSB/FM/AM = Modulation équilibrée/Modulation variable/Modulation à faible puissance
Rayonnement parasite de l'émetteur Less than -60dB
Rayonnement parasite de l'émetteur - 50 MHz Less than - 66 dB
Suppression des bandes latérales indésirables de l'émetteur Less than -60dB
Plage de fréquence XIT ± 9,999 kHz
Dimensions W x H x D = 460 x 182 x 449 mm including projections
Poids 24,5 kg
CW Features
Auto-Weighting, with adjustable manual fixed ratios
Built-In Memory Keyer
CW Autotransmit
CW Autotune
CW Pitch Control , Adjustable 300 - 1100Hz
CW-Reverse Mode
Full Break-In/Semi Break-In
Iambic Modes A and B Built-in
Microphone Paddle Mode
Paddle Reverse Function
Side Tone Monitor
Terminal for CW paddle key
Terminal for straight key/external electronic keyer
Source Radio Ham 33: http://www.radioham33.com/kenwood_hf.html
La brochure pdf est disponible ici: http://www.jbe.nl/downloads/3048/Kenwood%20TS990SE%20Brochure.pdf
Le manuel pdf est ici: http://www.kenwood.com/i/products/info/amateur/ts_990/pdf/TS-990S_IDM.pdf
#Kenwood #TS-990SE
- le Ven 11 Déc 2015 - 13:17
- Sujet: Kenwood TS-990SE
- Vues: 1280
Ven 26 Avr 2024 - 20:28 par 14KM5701
Ven 26 Avr 2024 - 15:53 par WarGames58
Ven 26 Avr 2024 - 7:37 par bernard69
Ven 26 Avr 2024 - 6:39 par bernard69
Ven 26 Avr 2024 - 1:02 par Dundee33
Ven 26 Avr 2024 - 1:01 par Dundee33
Ven 26 Avr 2024 - 0:54 par Dundee33
Jeu 25 Avr 2024 - 22:09 par 14KM5701
Jeu 25 Avr 2024 - 16:04 par Dundee33
Jeu 25 Avr 2024 - 10:44 par 14GEF027
Jeu 25 Avr 2024 - 8:19 par leglaude09
Mer 24 Avr 2024 - 23:28 par 14KM5701
Mer 24 Avr 2024 - 18:26 par Dundee33
Mar 23 Avr 2024 - 14:27 par Toubib
Mar 23 Avr 2024 - 0:17 par Dundee
Lun 22 Avr 2024 - 18:40 par Corsaire35
Lun 22 Avr 2024 - 18:03 par Dundee33
Lun 22 Avr 2024 - 17:04 par Dundee33
Lun 22 Avr 2024 - 16:36 par FE7964
Lun 22 Avr 2024 - 15:27 par 14ML73
Dim 21 Avr 2024 - 18:11 par 14jl7257
Dim 21 Avr 2024 - 18:11 par Dundee
Dim 21 Avr 2024 - 17:39 par Dundee33
Sam 20 Avr 2024 - 23:52 par Dundee
Sam 20 Avr 2024 - 22:21 par DOMI33
Sam 20 Avr 2024 - 9:42 par PAPA FOX
Sam 20 Avr 2024 - 3:04 par Dundee33
Ven 19 Avr 2024 - 22:14 par Dundee33
Ven 19 Avr 2024 - 22:13 par PAPA FOX
Ven 19 Avr 2024 - 20:58 par anonyme 79
Ven 19 Avr 2024 - 12:53 par linquisiteur
Ven 19 Avr 2024 - 11:35 par Dundee33
Ven 19 Avr 2024 - 7:05 par PAPA FOX
Ven 19 Avr 2024 - 0:13 par WarGames58
Jeu 18 Avr 2024 - 11:41 par franck666
Jeu 18 Avr 2024 - 6:51 par Dundee33
Mer 17 Avr 2024 - 23:42 par Le Nounours
Mer 17 Avr 2024 - 23:29 par Dundee33
Mer 17 Avr 2024 - 21:32 par Gils
Mer 17 Avr 2024 - 16:48 par 14ML73
Mer 17 Avr 2024 - 15:24 par benjd97
Mer 17 Avr 2024 - 10:32 par Dundee33
Mer 17 Avr 2024 - 9:48 par Dundee33
Mer 17 Avr 2024 - 9:06 par Dundee33
Mar 16 Avr 2024 - 21:30 par Dundee33
Mar 16 Avr 2024 - 21:02 par DEMON 72
Lun 15 Avr 2024 - 17:34 par Dundee33
