La date/heure actuelle est Mar 07 Mai 2024, 20:16
3 résultats trouvés pour TS-788DX
Sommerkamp TS-788DX (Mobile)
Fréquences: 26-30 MHz
Modes: AM / FM / USB / LSB
Puissance: Hi: 100 W (25 W AM carrier) / Lo: 10 W (5 W AM carrier)
- Channels/tuning steps: 100 Hz, 1 / 10 / 100 KHz
Mode: AM/FM/SSB/CW
Frequency control: PLL
Power supply: 11-16 VDC
Current drain/power consumption: RX: ? mA
TX: Max 20 A
Dimensions (W*H*D): 156*61*290 mm (6.14*2.4*11.42")
Weight: 2.7 Kg (5.95 lbs)
Other features: NB. RIT. SWR-meter.
RECEIVER SECTION
Receiver system: Single conversion superheterodyne
IF: 10.7 MHz
Sensitivity: AM/FM: 0.75 uV (10 d S/N)
SSB: 0.25 uV (10 dB S/N)
Selectivity: AM: 6 KHz (-6 dB)
SSB: 2.4 KHz (-6 dB), 4.8 KHz (-60 dB)
Image rejection: >50 dB
AF output power/speaker: 2.5 W at ?% distortion / 8 ohms
External speaker connector: 3.5 mm, 4-8 ohms
TRANSMITTER SECTION
Modulation system:
FM deviation: ±1.5 KHz
Spurious emissions: Less than -50 dB
Microphone impedance/connector: 600 ohms to 10 Kohm / 8-pin
- le Sam 10 Aoû 2019, 03:46
- Rechercher dans: Yeasu, Marc, Sommerkamp, Tokai, Yako
- Sujet: Sommerkamp TS-788DX (Mobile)
- Réponses: 22
- Vues: 2519
Fréquences: 26-30 MHz (100/10/1 KHz/100 Hz steps)
Modes: AM/FM/SSB/CW
Puissance: Hi: 100 W (25 W AM) - Lo: 20 W (5 W AM)
TX: Max 20 A
- Frequency control: PLL
Voltage: 11-16 VDC
Current drain: RX: Max ? A
Impedance: 50 ohms, SO-239
Manufactured: Japan, 197x-197x (Discontinued)
Other: Also known as "The coffeewarmer"
Microphone is switchable for use as a speaker-mike. This
is an interesting feature I've never seen before in a mobile
radio. Very useful in a noisy vehicle.
Des modifications sont disponible ici (pdf): [Vous devez être inscrit et connecté pour voir ce lien]
- le Dim 24 Jan 2016, 16:43
- Réponses: 22
- Vues: 2519
Sommerkamp TS-788DX
Type: Citizen band/freeband/export/amateur transceiver
Frequency range: 26-30 MHz (100/10/1 KHz/100 Hz steps)
Mode: AM/FM/SSB/CW
RF Power output: Hi: 100 W (25 W AM)
Lo: 20 W (5 W AM)
- Plus de détaille ici:
- Image rejection: >50 dB
Voltage: 11-16 VDC
TX: Max 20 A
Source: http://www.rigpix.com/
#Sommerkamp #TS-788DX
- le Sam 05 Déc 2015, 11:18
- Vues: 6332
Aujourd'hui à 19:32 par Asterix76
Aujourd'hui à 14:12 par Dundee33
Aujourd'hui à 00:40 par 14MJ24
Aujourd'hui à 00:06 par Dundee
Hier à 18:32 par cactus 85
Hier à 00:07 par Dundee33
Hier à 00:05 par Dundee33
Hier à 00:04 par Dundee33
Dim 05 Mai 2024, 20:08 par Asterix76
