La date/heure actuelle est Dim 28 Avr 2024, 13:43
1 résultat trouvé pour TS-520S
Kenwood TS-520S
Frequency range: 10-160 m in 8 bands
1.8-2.0 MHz
3.5-4.0 MHz
7.0-7.3 MHz
14.0-14.35 MHz
21.0-21.45 MHz
28.0-28.5 MHz
28.5-29.1 MHz
29.1-29.7 MHz
+ 15.0 MHz WWV receive only
Tuning steps: Continuous
Mode: SSB/CW
- Channels/memory management: 4 fixed XTAL channels
Repeater shift/offset: No
Power supply: Mains: 120 / 220 VAC or 13.8 VDC
Current drain/power consumption: RX: 5 A (heaters on), 0.6 A (heaters off) @ 13.8 VDC
TX: Max 15 A @ 13.8 VDC
Antenna impedance/connector: 50-75 ohms / SO-239
Dimensions (W*H*D): 333*153*335 mm (13.11*6.02*13.2")
Weight: 16 Kg (35.27 lbs)
Other features: NB, VOX, 25 KHz calibrator, Phone patch connectors
RECEIVER SECTION
Receiver system: ? conversion superheterodyne
Sensitivity: 0.25 uV (10 dB S+N/N)
Selectivity: SSB: 2.4 KHz (-6 dB), 4.4 KHz (-60 dB)
CW: 0.5 KHz (-6 dB), 1.5 KHz (-60 dB) with optional CW filter
Image rejection: 50 dB
AF output power/speaker: 1 W at 10% distortion / 8 ohms
External speaker connector:
TRANSMITTER SECTION
RF output power: SSB: ~100 W PEP (200 W PEP input)
CW: ~100 W DC (160 W DC input)
Modulation system:
Max FM deviation: No FM
Spurious emissions: Less than -40 dB
Microphone impedance/connector: 50 kohms / 4-pin
MISCELLANEOUS
Manufactured: Japan, 1977-197x (Discontinued)
Additional info: Tube hybrid: 3 tubes
Source: http://www.rigpix.com/
#Kenwood #TS-520S
- le Mar 25 Avr 2017, 22:29
- Sujet: Kenwood TS-520S
- Vues: 601
Ven 26 Avr 2024, 20:28 par 14KM5701
