La date/heure actuelle est Dim 28 Avr 2024 - 14:46
1 résultat trouvé pour TS-180S
Kenwood TS-180S
Type: Amateur HF transceiver
Frequency range: 10-160 m + 2*500 KHz AUX bands
1.8-2.0 MHz
3.5-4.0 MHz
7.0-7.3 MHz
14.0-14.35 MHz
21.0-21.45 MHz
28.0-29.7 MHz
- WWV 10 MHz (RX only)
Tuning steps: Continuous
Mode: SSB/CW/FSK
Memory channels: 4 tunable (if DFC-180 is installed)
Power supply: 11-16 VDC (13.8 VDC nominal)
Current drain/power consumption: RX: 1.2-1.6 A
TX: Max 20 A
Dimensions (W*H*D): 325*133*287 mm (12.5*5.4*11.2")
Weight: 11.5 Kg (25.4 lbs)
Other features: NB, Dual RIT, IF Shift, VOX, Transverter terminals
RECEIVER SECTION
Receiver system: Single conversion superheterodyne
IF: 8.830 MHz
Sensitivity: 0.25 uV S+N/N
Selectivity: SSB/CW wide: 2.4 KHz (-6 dB), 4.2 KHz (-60 dB)
FSK/CW narrow with YK-88C: 0.5 KHz (-6 dB), 1.8 KHz (-60 dB)
Image rejection: 60 dB
AF output power/speaker: 2 W at 10% distortion / 4 ohm
External speaker connector: 4-16 ohm
TRANSMITTER SECTION
RF output power: Max 100 W (slightly less on 10 m)
Modulation system:
Max FM deviation: No FM
Spurious emissions: Less than -50 dB
Microphone connector/impedance: 4-pin / 500 ohm to 50 kohm
MISCELLANEOUS
Manufactured: Japan, 1979-198x (Discontinued)
Additional info:
Related documents: User manual (5.9 MB)
Modifications:
Options/Accessories:
AT-180
DFC-180
HS-4
HS-5
MC-35S
MC-50
PC-1
PS-30
SM-220
SP-180
VFO-180
YK-88C
YK-88S Antenna tuner with SWR/power meter and antenna switch
Digital frequency control
headphones
headphones
Hand microphone, 50 kohm
Desk microphone, 500 ohm/50 kohm
Phone patch
Power supply
Station monitor
External speaker with filters
Remote VFO
CW filter, 500 Hz
SSB filter, 2.2 KHz
Source: http://www.rigpix.com/kenwood/kenwoodselect.htm
#Kenwood #TS-180S
- le Sam 16 Déc 2017 - 12:01
- Sujet: Kenwood TS-180S
- Vues: 1964
Ven 26 Avr 2024 - 20:28 par 14KM5701
Ven 26 Avr 2024 - 15:53 par WarGames58
Ven 26 Avr 2024 - 7:37 par bernard69
Ven 26 Avr 2024 - 6:39 par bernard69
Ven 26 Avr 2024 - 1:02 par Dundee33
Ven 26 Avr 2024 - 1:01 par Dundee33
Ven 26 Avr 2024 - 0:54 par Dundee33
Jeu 25 Avr 2024 - 22:09 par 14KM5701
Jeu 25 Avr 2024 - 16:04 par Dundee33
Jeu 25 Avr 2024 - 10:44 par 14GEF027
Jeu 25 Avr 2024 - 8:19 par leglaude09
Mer 24 Avr 2024 - 23:28 par 14KM5701
Mer 24 Avr 2024 - 18:26 par Dundee33
Mar 23 Avr 2024 - 14:27 par Toubib
Mar 23 Avr 2024 - 0:17 par Dundee
Lun 22 Avr 2024 - 18:40 par Corsaire35
Lun 22 Avr 2024 - 18:03 par Dundee33
Lun 22 Avr 2024 - 17:04 par Dundee33
Lun 22 Avr 2024 - 16:36 par FE7964
Lun 22 Avr 2024 - 15:27 par 14ML73
Dim 21 Avr 2024 - 18:11 par 14jl7257
Dim 21 Avr 2024 - 18:11 par Dundee
Dim 21 Avr 2024 - 17:39 par Dundee33
Sam 20 Avr 2024 - 23:52 par Dundee
Sam 20 Avr 2024 - 22:21 par DOMI33
Sam 20 Avr 2024 - 9:42 par PAPA FOX
Sam 20 Avr 2024 - 3:04 par Dundee33
Ven 19 Avr 2024 - 22:14 par Dundee33
Ven 19 Avr 2024 - 22:13 par PAPA FOX
Ven 19 Avr 2024 - 20:58 par anonyme 79
Ven 19 Avr 2024 - 12:53 par linquisiteur
Ven 19 Avr 2024 - 11:35 par Dundee33
Ven 19 Avr 2024 - 7:05 par PAPA FOX
Ven 19 Avr 2024 - 0:13 par WarGames58
Jeu 18 Avr 2024 - 11:41 par franck666
Jeu 18 Avr 2024 - 6:51 par Dundee33
Mer 17 Avr 2024 - 23:42 par Le Nounours
Mer 17 Avr 2024 - 23:29 par Dundee33
Mer 17 Avr 2024 - 21:32 par Gils
Mer 17 Avr 2024 - 16:48 par 14ML73
Mer 17 Avr 2024 - 15:24 par benjd97
Mer 17 Avr 2024 - 10:32 par Dundee33
Mer 17 Avr 2024 - 9:48 par Dundee33
Mer 17 Avr 2024 - 9:06 par Dundee33
Mar 16 Avr 2024 - 21:30 par Dundee33
Mar 16 Avr 2024 - 21:02 par DEMON 72
Lun 15 Avr 2024 - 17:34 par Dundee33
