La date/heure actuelle est Sam 27 Avr 2024, 14:57
2 résultats trouvés pour RCI-2995
Postes Tuning
Source: facebook Québec
- le Jeu 01 Mar 2018, 10:59
- Sujet: Postes Tuning
- Réponses: 693
- Vues: 37285
Ranger RCI-2995 DX CF (Base)
(Poste R.A. vendu aux Cibistes)• 10 & 12 Meter Bands
• Emission: USB, LSB, CW, AM, FM
• RF Power Output:
50 Watts RMS: CW / AM / FM
150 Watts (PEP): SSB
- Features:
• Large Frequency Display with Dimmer
• Improved Receiver Design
• New Backlite Display
• Variable Output Power Control
• Active Frequency Scanner
• 16 Programmable/Erasable Frequencies
• Programmable Repeater Split
• Receiver Clarifier (±0.5 KHz)
• Dual Panel Meters
• Noise Blanker/ANL Circuitry
• Frequency Selector Lockout
• Continuous Duty Built-in AC Power Supply
• 2 Year Warranty
General
• Frequency Range:
10 Mtr: 28.000 - 29.6999 MHz
12 Mtr: 24.8900 - 24.9900 MHz
• Tuning Steps: 1 MHz, 100 KHz, 10 KHz, 1 KHz, 100 Hz
• Clarifier Range: ±5 KHz
• Frequency Tolerance: 0.005%
• Frequency Stability: 0.001%
• Operating Temperature Range: - 20 ºC to + 50 ºC
• Meters :
Left: RX Signal Strength
Right: RF Output, Antenna SWR
• Antenna Impedance: 50 Ohm
• Input Voltage: 110 VAC, 60 Hz ( 220 VAC, 50 Hz Optional )
• AC Power Consumptions: 300 Watts
• Microphone: 400 Ohm Dynamic PTT - 6 Pin
Transmitter
• Modes: USB, LSB, CW, AM, FM
• Carrier Suppression: Better Than 60 dB
• Spurious Emission: More Than 60 dB
• Antenna Connector: Standard SO-239 Type
• Output Impedance: Unbalanced 50 Ohm
Receiver
• Sensitivity:
AM / CW: 0.7 µV for 10 dB SINAD
FM: 0.5 µV for 12 dB SINAD
SSB: 0.2 µV for 10 dB SINAD
• AM / FM Selectivity: 50 dB at 10 KHz
• SSB Selectivity: 5 dB at 2 KHz, 60 db at 4 KHz
• Image Rejection: More than 50 dB
• IF Rejection: More than 80 dB at 455 KHz
• Audio Output Power: 2.5 Watts @ 10% THD
• Intermod Rejection: > 50 dB
• Noise Blanker: IF Single Gate Type
• Built In Speaker: 8 Ohm
• External Speaker: Disables Internal Speaker when Connected, 8 Ohm
Source Pays-Bas: https://www.avera.eu/trx-transceivers-cb.html
#Ranger #RCI-2995 #DX #CF
- le Lun 15 Mai 2017, 17:32
- Rechercher dans: Ranger, Mirage, Sea Eagle, Texas, Voyage
- Sujet: Ranger RCI-2995 DX CF (Base)
- Réponses: 8
- Vues: 3973
Aujourd'hui à 14:07 par Le Nounours
Hier à 07:37 par bernard69
Hier à 06:39 par bernard69
Hier à 01:02 par Dundee33
Hier à 01:01 par Dundee33
Hier à 00:54 par Dundee33
