La date/heure actuelle est Jeu 02 Mai 2024, 17:13
2 résultats trouvés pour MD-1
Top Gun MD-1 Modulator & CP-1 Compressor
MD-1 Modulator
Now the same Top Gun Modulator MD-1 and Compressor CP-1 circuits used in the new Magnum radios are available for most other 10-meter and many CB radios. Full tone, clear, high swing audio (AM) modulation is achieved with the addition of these two fully assembled micro circuit boards. While the Top Gun Modulator works only in AM, the Top Gun Compressor works in AM, FM, and SSB keeping the modulation at peak performance in all these modes. Installation is accomplished with the removal of up to 3 resistors and the connection of 7 to 9 pre stripped and tinned wires. Instructions are included for current and past production compatible radios. Additional Web support is available at www.TopGunTec.com. These circuits work with or without the modulation limiter. For the purest, the limiter can be adjusted for excellent forward swing without any square wave audio. Without the limiter the compressor maintains high-level audio without severe squaring of the audio signal. It is the squaring of the audio peaks that create the distortion and splatter of adjacent frequencies. On 30-50 Watt radios, the dead-key or carrier can be set to 2 Watt or less with a modulation swing to the full output potential of the radio transmitter. The modulator can be switched to normal swing with the installation of an optional SPST or SPDT switch. Even in the normal swing mode, the Top Gun Modulator is still working to keep the audio clean at all power levels.
Maintenant, les mêmes circuits Top-Gun Modulator MD-1 et Compressor CP-1 utilisés dans les nouvelles radios Magnum sont disponibles pour la plupart des autres radios de 10 mètres et de nombreuses radios CB. Une tonalité intégrale, claire, une modulation audio à amplitude de modulation élevée (AM) est obtenue grâce à l'ajout de ces deux cartes de circuit imprimé entièrement assemblées. Alors que le Top Gun Modulator ne fonctionne que sur AM, le Top Gun Compressor fonctionne en AM, FM et SSB, ce qui permet à la modulation d'atteindre des performances optimales dans tous ces modes. L'installation est accomplie avec l'enlèvement de jusqu'à 3 résistances et la connexion de 7 à 9 fils pré dénudés et étamés. Des instructions sont incluses pour les radios compatibles actuelles et passées. Un support Web supplémentaire est disponible sur www.TopGunTec.com. Ces circuits fonctionnent avec ou sans le limiteur de modulation. Pour le plus pur, le limiteur peut être ajusté pour un excellent swing vers l'avant sans aucun son carré. Sans le limiteur, le compresseur maintient un son de haut niveau sans quadrature sévère du signal audio. C'est la quadrature des pics audio qui crée la distorsion et l'éclaboussement des fréquences adjacentes. Sur les radios 30-50 Watt, la touche morte ou le support peut être réglé sur 2 Watt ou moins avec un basculement de modulation au potentiel de sortie complet de l'émetteur radio. Le modulateur peut être basculé en mode normal avec l'installation d'un commutateur SPST ou SPDT en option. Même en mode swing normal, le Top Gun Modulator fonctionne toujours pour garder le son propre à tous les niveaux de puissance
200mv P-P 1KHz Sine Wave At Mic Input
Onde sinusoïdale de 200mv P-P 1KHz à l'entrée de micro
AM Modulated Signal With The Top Gun Modulator In The OFF Position. - Same Modulated Signal With The Top Gun Modulator In The ON Position
(Google translation translator traduction)Signal modulé AM avec le modulateur Top Gun en position OFF. - Même signal modulé avec le modulateur Top Gun en position ON
Retrouvez d'autres mesures ici: http://www.topguntec.com/tgt_md_1.htm
#Top #Gun #technologies #MD-1 #Modulator
- le Mer 30 Mai 2018, 22:25
- Sujet: Top Gun MD-1 Modulator & CP-1 Compressor
- Vues: 1180
Pour Radios CB Galaxy Ranger Connex RCI
Modes: AM, SSB
1- Top Gun Technologies MD-1 Modulator: AM modulator swings from 1 watt to full power
1- Top Gun Technologies CP-1 all mode compressor: for SSB operation
1- Modulateur MD-1 de Top Gun Technologies: le modulateur AM oscille de 1 watt à pleine puissance
1- Compresseur tout mode Top Gun Technologies CP-1: pour fonctionnement en SSB
Source direct (Allemagne): https://www.ebay.com/itm/TOP-GUN-MD-1-MODULATOR-CP-1-COMPRESSOR-For-CB-Radios-Galaxy-Ranger-Connex-RCI-/
#Top #Gun #MD-1 #Modulator #CP-1 #Compressor
- le Mer 30 Mai 2018, 22:14
- Vues: 1180
Aujourd'hui à 16:52 par Dundee33
Aujourd'hui à 15:13 par Lannig92
Aujourd'hui à 14:07 par Dundee33
Aujourd'hui à 14:01 par leglaude09
Aujourd'hui à 12:06 par WarGames58
Aujourd'hui à 11:39 par WarGames58
Aujourd'hui à 08:52 par leglaude09
Aujourd'hui à 04:45 par Dundee33
Aujourd'hui à 04:35 par Dundee33
Aujourd'hui à 04:00 par Dundee33
Aujourd'hui à 03:51 par Dundee33
Aujourd'hui à 02:55 par Dundee33
Aujourd'hui à 02:49 par Dundee33
Aujourd'hui à 02:31 par Dundee33
Aujourd'hui à 01:53 par Dundee33
