La date/heure actuelle est Jeu 2 Mai - 21:50
1 résultat trouvé pour CD-201M
Jeil CD-201M (Micro de table)
Selectable for 2 sets of transceivers at once by slide switch.
High Sensitivity Electret Condenser Microphone Element equipped.
High Quality Compressor Amplifier ( High - Low selectable ) built-in. It sends out constant and optimum level without distortion regardless of audio input level.
Equipped with FM(AM)/SSB Audio Quality Selector Switch for optimum operation. The Electret Condenser Microphone ensures clearer voice quality in FM(AM) position and better voice quality on SSB.
- Non-Modulation Prevention Circuit built-in.
After continuous transmitting for a few minutes, the alarm circuit will be activated with alarm
sound for 30 seconds. Then, the condition returns to receiving mode automatically.
Battery-Check Circuit built-in.
Turn the power switch on ( by selecting ''FM' or ''SSB'' position ), and the level meter indicates
the battery condition with power voltage for a few seconds.]
Amplification:
High - 45dB
Low - 35dB
Manual
Dual Microphone Connectors Output:
Output A 8 Pin Standard Microphone Plug
Output B 8 Pin Standard Microphone Plug
Front panel switch controlled.
Meter - Dual Display
VU (Volume Unit)
Battery Indicator
1-1/2" H x 2" W
Buttons :
Output Select ~ [Out A] [Out B] [Out-Off]
Compression Level ~ [High] [Low] [Manual]
Manual Compression Control Knob [Minimum] ~ [Maximum]
Mode ~ [SSB] [FM] [Battery-Check]
Channel Control Switch ~ [Up] [Down]
Key Controls ~ [PTT] [Lock]
Output Voltage:
Amplification - 0.3mv (Lapse)
Variable Amplification: 0-70mv(Lapse)
Output Resistance:
500 W ~ 100k W
Batteries Required:
3 ~ AAA: Not Included
Only one mic cord is included, additional one can be purchased
- Sélectionnable pour 2 ensembles d'émetteurs-récepteurs à la fois par interrupteur à glissière.
Élément de microphone à condensateur d'électret haute sensibilité équipé.
Amplificateur de compresseur de haute qualité (sélectionnable haut-bas) intégré. Il envoie un niveau constant et optimal sans distorsion quel que soit le niveau d'entrée audio.
Équipé d'un sélecteur de qualité audio FM (AM) / SSB pour un fonctionnement optimal. Le microphone électrostatique à condensateur garantit une qualité vocale plus claire en position FM (AM) et une meilleure qualité vocale sur SSB.
Circuit de prévention de non-modulation intégré.
Après une transmission continue pendant quelques minutes, le circuit d'alarme sera activé avec alarme
son pendant 30 secondes. Ensuite, la condition revient automatiquement en mode de réception.
Circuit de vérification de la batterie intégré.
Allumez l'interrupteur d'alimentation (en sélectionnant la position '' FM '' ou '' SSB '') et l'indicateur de niveau indique
l'état de la batterie avec la tension d'alimentation pendant quelques secondes.]
Amplification:
Élevé - 45 dB
Faible - 35 dB
Manuel
Sortie de connecteurs de microphone double:
Sortie une prise de microphone standard à 8 broches
Sortie B Fiche microphone standard 8 broches
Interrupteur du panneau avant contrôlé.
Compteur - Double affichage
VU (unité de volume)
Indicateur de batterie
1-1 / 2 "H x 2" L
Boutons :
Sélection de sortie ~ [Out A] [Out B] [Out-Off]
Niveau de compression ~ [Élevé] [Faible] [Manuel]
Bouton de commande de compression manuelle [Minimum] ~ [Maximum]
Commutateur de contrôle des canaux ~ [Haut] [Bas]
Commandes de touches ~ [PTT] [Lock]
Tension de sortie:
Amplification - 0,3 mv (Lapse)
Amplification variable: 0-70mv (Lapse)
Résistance de sortie:
500 W ~ 100k W
Piles requises:
3 ~ AAA: non inclus
Un seul cordon micro est inclus, un autre peut être acheté
Source USA: https://www.copperelectronics.com/cart/Microphones-CB
#Jeil #Communications #CD-201M #Micro
- le Mer 15 Juil - 22:28
- Sujet: Jeil CD-201M (Micro de table)
- Vues: 690
Aujourd'hui à 18:30 par DEMON 72
Aujourd'hui à 18:30 par bernard69
Aujourd'hui à 16:52 par Dundee33
Aujourd'hui à 14:07 par Dundee33
Aujourd'hui à 12:06 par WarGames58
Aujourd'hui à 11:39 par WarGames58
Aujourd'hui à 8:52 par leglaude09
Aujourd'hui à 4:45 par Dundee33
Aujourd'hui à 4:35 par Dundee33
Aujourd'hui à 4:00 par Dundee33
Aujourd'hui à 3:51 par Dundee33
Aujourd'hui à 2:55 par Dundee33
Aujourd'hui à 2:49 par Dundee33
Aujourd'hui à 2:31 par Dundee33
Aujourd'hui à 1:53 par Dundee33
Mar 30 Avr - 16:57 par Asterix76
Mar 30 Avr - 11:51 par Le Nounours
Mar 30 Avr - 10:10 par 16bg002 alain
Lun 29 Avr - 20:49 par WarGames58
Lun 29 Avr - 20:28 par DEMON 72
Lun 29 Avr - 18:45 par DEMON 72
Lun 29 Avr - 17:37 par Dundee33
Lun 29 Avr - 9:15 par FE7964
Dim 28 Avr - 22:18 par 14KM5701
Sam 27 Avr - 18:37 par WarGames58
Sam 27 Avr - 14:07 par Le Nounours
Ven 26 Avr - 15:53 par WarGames58
Ven 26 Avr - 7:37 par bernard69
Ven 26 Avr - 6:39 par bernard69
Ven 26 Avr - 1:02 par Dundee33
Ven 26 Avr - 1:01 par Dundee33
Ven 26 Avr - 0:54 par Dundee33
Jeu 25 Avr - 16:04 par Dundee33
Jeu 25 Avr - 8:19 par leglaude09
Mar 23 Avr - 0:17 par Dundee
Lun 22 Avr - 18:40 par Corsaire35
Lun 22 Avr - 18:03 par Dundee33
Lun 22 Avr - 17:04 par Dundee33
Lun 22 Avr - 16:36 par FE7964
Lun 22 Avr - 15:27 par 14ML73
