Air 802 Flex CA400 (Câble coaxial 11mm)
La Planète Cibi Francophone :: Le matériel de la Planète Cibi (Récent & nouveaux) :: Antennes Cibi Fixes :: Accessoires Antennes Fixes (HF)
CA400FLEX cable offers equivalent characteristics and performance to Times Microwave LMR-400UF ultraflex cable. This 50 ohm cable is significantly more flexible than CA400 due to the construction with stranded center conductors and a TPE jacket material. This cable is also an alternative to RG 213.
- It is manufactured with a thermoplastic elastomer (TPE) jacket. TPE has rubber-like properties and is sometimes referred to as thermoplastic rubber. TPE offers excellent environmental and chemical characteristics. There are considerable variances in TPE material. AIR802 engineering identified the best TPE material for use on antenna cables which might be installed in extreme cold to heat from DuPont Corporation. Other materials whether TPE or not if not appropriately chosen may result in stiffening when installed in extreme cold, suffer from UV radiation breakdown and other issue. Using the appropriate TPE material provides good abrasion resistance, heat resistance, resistance to UV sunlight, oxidation and atmospheric ozone. It does not have high resistance to hydrocarbons and would not be the most suitable for refining or gas processing plants. It is resistant to wear, cutting and impact. TPE retains its physical and electrical properties even in severe environmental conditions such as salt water making it very suitable for marine use.
This cable is constructed of stranded center conductors and coupled with the rubber-like TPE jacket provides for superior bending and flexibility. CA400FLEX has excellent weatherability engineered for up to 20 years of life.
Applications
Antenna Cable Runs to Base Stations, Access Points (AP), Bridges or CPE
Cabling between any antenna and the associated radio equipment
Indoor or Outdoor Use
Tower Use
Land Mobile Radio (LMR)
Local MultiPoint Distribution System (LMDS)
Multi-Channel Multi-Point Distribution Service (MMDS)
Wireless Local Loop (WLL)
Personal Communication Systems (PCS)
Mobile
Marine Use on Yachts, Sailboats, etc.
Fixed Wireless
GPS
SCADA
Ham Radio
CB Radio
- Traduction Goggle:
- Le câble CA400FLEX offre des caractéristiques et des performances équivalentes au câble ultraflex Times Microwave LMR-400UF. Ce câble de 50 ohms est nettement plus flexible que le CA400 grâce à sa construction avec des conducteurs centraux toronnés et un matériau de gaine TPE. Ce câble est également une alternative au RG 213.
Il est fabriqué avec une gaine en élastomère thermoplastique (TPE). Le TPE a des propriétés caoutchouteuses et est parfois appelé caoutchouc thermoplastique. Le TPE offre d'excellentes caractéristiques environnementales et chimiques. Il existe des écarts considérables dans le matériau TPE. L'ingénierie AIR802 a identifié le meilleur matériau TPE à utiliser sur les câbles d'antenne qui pourraient être installés dans un froid extrême pour chauffer de DuPont Corporation. D'autres matériaux, qu'ils soient en TPE ou non, s'ils ne sont pas choisis de manière appropriée, peuvent entraîner un raidissement lorsqu'ils sont installés dans un froid extrême, souffrir de la dégradation des rayons UV et d'autres problèmes. L'utilisation du matériau TPE approprié offre une bonne résistance à l'abrasion, à la chaleur, à la lumière solaire UV, à l'oxydation et à l'ozone atmosphérique. Il n'a pas une grande résistance aux hydrocarbures et ne serait pas le plus approprié pour les usines de raffinage ou de traitement de gaz. Il résiste à l'usure, aux coupures et aux chocs. Le TPE conserve ses propriétés physiques et électriques même dans des conditions environnementales sévères telles que l'eau salée, ce qui le rend très approprié pour une utilisation marine.
Ce câble est constitué de conducteurs centraux toronnés et couplé à la gaine TPE de type caoutchouc pour une flexion et une flexibilité supérieures. Le CA400FLEX a une excellente résistance aux intempéries conçue pour une durée de vie pouvant atteindre 20 ans.
Applications
Le câble d'antenne passe aux stations de base, aux points d'accès (AP), aux ponts ou au CPE
Câblage entre toute antenne et l'équipement radio associé
Utilisation intérieure ou extérieure
Utilisation de la tour
Radio mobile terrestre (LMR)
Système de distribution multipoint local (LMDS)
Service de distribution multipoint multicanal (MMDS)
Boucle locale sans fil (WLL)
Systèmes de communication personnels (PCS)
Mobile
Utilisation marine sur les yachts, voiliers, etc.
Sans fil fixe
GPS
SCADA
Ham Radio
Radio CB
Source USA: https://www.copperelectronics.com/cart/Coax-Cable
#Air #802 #Flex #CA400 #câble #coax
Hier à 20:31 par BZH Vincent
Hier à 16:53 par WarGames58
Hier à 13:57 par Dundee33
Hier à 13:46 par Dundee33
Hier à 13:45 par Dundee33
Hier à 13:37 par Dundee33
Hier à 12:36 par 14KM2914
Hier à 05:47 par Rancho84
Hier à 04:03 par Dundee33
Hier à 03:41 par Dundee33
Hier à 03:29 par 14ML73
Hier à 03:20 par Dundee33
Hier à 03:15 par 14KM5701
Mer 15 Mai 2024, 23:04 par Rémi du 82
Mar 14 Mai 2024, 06:35 par Dundee33
