La date/heure actuelle est Lun 18 Oct 2021, 01:12
1 résultat trouvé pour M-8900
Maxlog M-8900 (Mobile)
Tag m-8900 sur La Planète Cibi Francophone Maxlog10
GENERAL SPECIFICATIONS:
Frequency Coverage: 25.615 to 30.105 Mhz or 24.500-25.615 Mhz in export mode selectable from front panel Antenna Impedance: 50 ohm, unbalanced Frequency Control: Digital Phase-Lock Loop (PLL) Synthesizer Frequency Accuracy: Better than +10 ppm from 0 - 40 °C after 15 min. warm up Power Requirement: 12 -13.8 V DC, negative ground Current Consumption: 9 amps maximum Dimensions: 17.5 x 18.2 x 5.3mm (D x W x H) Weight: 1.5kg Does not included USB Programming cable Does not come with manufacturer's packaging - it comes in a plain eco-friendly cardboard box 6 PIN PRESIDENT WIRED TRANSMITTER SPECIFICATIONS Power Output: SSB/CW/ FM...40 Watts, ...AM..10 Watts RMS / 40 Watts PEP Tuning Steps: 5/100hz /1 kHz /10 kHz/100khz Final Transistors: IRF520 MOSFET (x2) Spurious Emissions: More than 50 dB below peak output power Carrier Suppression: More than 40 dB below peak output power Unwanted Sideband: More than 50 dB below peak output (1 kHz tone) FM Deviation: +/- 5 kHz maximum Audio Response: More than 30dB below peak output Frequency Response: 400 to 2800 Hz Microphone Impedance: , 600 to 1 K ohms
Source Angleterre: http://www.amazon.co.uk/
Tag m-8900 sur La Planète Cibi Francophone M8900-10
#Maxlog #M-8900
le Mar 05 Avr 2016, 19:53
Rechercher dans: Marcom | Maxlog | MegaJet | Mega System | M-Tech
Sujet: Maxlog M-8900 (Mobile)
Réponses: 12
Vues: 1980
