La date/heure actuelle est Jeu 28 Mar 2024, 22:31
68 résultats trouvés pour Hy-Gain
Hy-Gain 16 (2716) (Mike / Mobile)
Année: 1977
- le Mer 29 Mar 2023, 16:06
- Sujet: Hy-Gain 16 (2716) (Mike / Mobile)
- Vues: 172
Hy-Gain 623 (Base)
Modes: AM / USB / LSB
Puissance: 12 W
- le Mer 11 Nov 2020, 19:51
- Sujet: Hy-Gain 623 (Base)
- Vues: 226
Hy-Gain SPT-500
Gain (dB) 5.3 dB
SWR (at resonance) Less than 1.2:1
Nominal input impedance 52 Ohms
- Lightning Protection DC Ground
Height 6.858 metres ( 22.5ft )
Radial Length 2.67 metres ( 8 ft 9 " )
Wind (Survival) 128 km/h ( 80 MPH )
Accepted mast size 3.175 cm to 4.5 cm ( 1 ¼” to 1 3/4 ”) OD
This fantastic true full-size 5/8 Wave 10 / 11 / 12 Metre vertical antenna from Hy-Gain was a legend in the 70’s . . . now it’s back to prove its legendary status once again!
A Full-size radiator with lower radiation angle concentrates power closer to the ground, where you want it. Measures 22 foot, 9.5 inches. Larger diameter, heavy wall ply-tubular construction makes the new Super-Penetrator the absolute top omnidirectional antenna around! Four full-length radials and special machine-formed brackets give extra talk-power and overall strength.
Electrical performance has been increased to a new standard by the use of a longer radiator and double-matching tuning with linear phasing techniques that provide low SWR and more radiated energy. The double-matching also provides a DC path to ground to drain off precipitation static, giving an extremely low noise antenna capable of high power.
- Gain (dB) 5,3 dB
SWR (à résonance) Moins de 1,2: 1
Impédance d'entrée nominale 52 Ohms
Protection contre la foudre DC Ground
Hauteur 6,858 mètres (22,5 pieds)
Longueur radiale 2,67 mètres (8 pi 9 po)
Vent (survie) 128 km / h (80 MPH)
Taille de mât acceptée 3,175 cm à 4,5 cm (1 ¼ "à 1 3/4") OD
Cette fantastique antenne verticale pleine grandeur 5/8 vagues 10/11/12 mètres de Hy-Gain était une légende dans les années 70. . . il est maintenant de retour pour prouver une fois de plus son statut légendaire!
Un radiateur pleine grandeur avec un angle de rayonnement plus faible concentre la puissance plus près du sol, où vous le souhaitez. Mesure 22 pieds, 9,5 pouces. La construction tubulaire à plis épais de plus grand diamètre fait du nouveau Super-Penetrator l'antenne omnidirectionnelle absolue absolue! Quatre radiaux pleine longueur et des supports spéciaux formés par machine offrent une puissance de conversation et une force globale supplémentaires.
Les performances électriques ont été augmentées à une nouvelle norme grâce à l'utilisation d'un radiateur plus long et d'un réglage à double adaptation avec des techniques de phasage linéaire qui fournissent un faible SWR et plus d'énergie rayonnée. La double correspondance fournit également un chemin CC vers la terre pour drainer les précipitations statiques, donnant une antenne à très faible bruit capable d'une puissance élevée.
Source Canada: https://www.radioworld.ca/cb-radio/z-rad-cbr
#Hy-Gain #SPT-500
- le Ven 17 Juil 2020, 15:22
- Sujet: Hy-Gain SPT-500
- Vues: 695
Hy-Gain Co-Phaser "Talk Power"
Source: http://www.oldtuberadio.com/category/radio-service/cb/
#Hy-Gain #Co-Phaser
- le Lun 13 Jan 2020, 17:10
- Sujet: Hy-Gain Co-Phaser "Talk Power"
- Vues: 488
Hy-Gain Goldenrod (Antenne fixe)
#Hy-Gain #Goldenrod
- le Lun 13 Jan 2020, 17:03
- Sujet: Hy-Gain Goldenrod (Antenne fixe)
- Vues: 123
Hy-Gain CBV (Antenne fixe)
#Hy-Gain #CBV
- le Lun 13 Jan 2020, 17:00
- Sujet: Hy-Gain CBV (Antenne fixe)
- Vues: 103
Hy-Gain CBGP (Antenne fixe)
#Hy-Gain #CBGP
- le Lun 13 Jan 2020, 16:57
- Sujet: Hy-Gain CBGP (Antenne fixe)
- Vues: 94
Hy-Gain CLR2 (Antenne fixe)
#Hy-Gain #CLR2
- le Lun 13 Jan 2020, 16:47
- Sujet: Hy-Gain CLR2 (Antenne fixe)
- Vues: 213
Hy-Gain CB3 (Antenne fixe)
#Hy-Gain #CB3
- le Lun 13 Jan 2020, 16:43
- Sujet: Hy-Gain CB3 (Antenne fixe)
- Vues: 190
Hy-Gain Long John (Antenne fixe)
#Hy-Gain #Long #John
- le Lun 13 Jan 2020, 16:39
- Sujet: Hy-Gain Long John (Antenne fixe)
- Vues: 244
Hy-Gain Eliminator ... (Antenne fixe)
#Hy-Gain #Eliminator
- le Lun 13 Jan 2020, 16:36
- Sujet: Hy-Gain Eliminator ... (Antenne fixe)
- Vues: 452
Hy-Gain Super Duo-Beam 10 ... (Antenne fixe)
#Hy-Gain #Super #Duo-Beam #4
- le Lun 13 Jan 2020, 16:31
- Sujet: Hy-Gain Super Duo-Beam 10 ... (Antenne fixe)
- Vues: 605
#Hy-Gain #Super #Duo-Beam #6
- le Lun 13 Jan 2020, 16:28
- Vues: 605
#Hy-Gain #Super #Duo-Beam #10
- le Lun 13 Jan 2020, 16:21
- Vues: 605
Hy-Gain Galaxy GT-550A
Lampes / Tubes: 11: 12BZ6 6HG8 6KE8 6EW6 12BA6 6GX6 12AT7 6EJ7 6GK6 6LB6 6LB6 0C2 0C2
Semi-conducteurs: (seuls les transistors sont comptés) 16: 2N2646 2N2926 unknown_tr 2N4105 2N4106 2N3563 2N3638
Principe général: Transceiver (poste récepteur/émetteur combiné)
Plus de détails ici a écrit:Gammes d'ondes: Ondes courtes (seulement OC)
Tension / type courant: Alimentation externe ou alimentation principale. / AC 12.6 & DC -100 & 16 & 350 & 800 Volt
Haut-parleur: This model requires external speaker(s).
Modèle: Hy-Gain GT-550A - Galaxy Electronics, Council
Matière: Boitier métallique
Forme: Modèle de table de forme quelconque, profil pas précisés.
Galaxy Electronics Hy-Gain GT-550A is a SSB/CW Transceiver for the SW 80 - 10 m HAM bands.
Input: SSB 550 W, CW 360 W
Source: https://www.radiomuseum.org/
#Hy-Gain #Galaxy #GT-550A
- le Jeu 29 Aoû 2019, 15:43
- Sujet: Hy-Gain Galaxy GT-550A
- Vues: 419
Hy-Gain CLR 2 (Antenne fixe)
Bandes: 27 MHz - 5/8ème
Gain: 4 dBi
Puissance maxi: 300 W
Impédance: 50 ohms, SO-239
Longueur: 6.04 m
Poids: 3.5 Kg
Années: 197...-198...
Source: http://www.rigpix.com/antennas/antennas.htm
#Hy-Gain #CLR #2 #GLR2
- le Lun 17 Déc 2018, 03:54
- Sujet: Hy-Gain CLR 2 (Antenne fixe)
- Vues: 793
Hy-Gain CB Transceiver (Mobile)
- le Dim 03 Juin 2018, 02:48
- Sujet: Hy-Gain CB Transceiver (Mobile)
- Vues: 618
Hy-Gain III (2703) (Mobile)
Channels: 40
Power Output: 4 W
- Frequency Control: PLL
Manufactured: 197x-197x
Other: Japan, 197x-197x
PCB by Cybernet Enterprise Japan
- le Sam 10 Fév 2018, 03:31
- Sujet: Hy-Gain III (2703) (Mobile)
- Vues: 870
Hy-Gain Hy-Range V (674A) (Mobile)
VFO externe pour Hy-Gain Hy-Range V (674A)
Année: 1975
- le Mar 21 Nov 2017, 01:10
- Sujet: Hy-Gain Hy-Range V (674A) (Mobile)
- Vues: 678
Modèle 674 - CBSAMS 70
canaux: 23
Ce modèle pouvait recevoir un VFO en accessoire externe (pour la réception uniquement) qui pouvait être modifié pour une utilisation sur transmission.
D'autres infos ici: [Vous devez être inscrit et connecté pour voir ce lien]
- le Dim 19 Nov 2017, 22:01
- Vues: 678
Hy-Gain Mobile Toppers (Antenne mobile)
Source: http://www.cbtricks.com/ant_manuals/hygain/model_tltm/ad/index.htm
#Hy-Gain #Mobile #Toppers
- le Dim 19 Nov 2017, 17:08
- Sujet: Hy-Gain Mobile Toppers (Antenne mobile)
- Vues: 710
Hy-Gain CLR II (Antenne fixe)
Band(s): 27 MHz - 5/8 wave
Gain: 4 dBi
Max power: 300 W
- Impedance: 50 ohms, SO-239
Length: 6.04 m
Weight: 3.5 Kg
Manufactured: 197x-198x
Source: http://www.rigpix.com/antennas/antennas.htm#hygain
#Hy-Gain #CLR #II
- le Dim 19 Nov 2017, 16:34
- Sujet: Hy-Gain CLR II (Antenne fixe)
- Vues: 606
Hy-Gain 12 (1292) (Portable)
Canaux: 6
- Frequency control: 2*XTAL/channel
Power supply: 9-15 VDC
Antenna impedance/connector: 50 ohms / Built-in telescopic whip
Receiver system: Single conversion superheterodyne
IF: 455 KHz
Sensitivity: 1 uV (no reference)
AF output power/speaker: 800 mW at ?% distortion / 8 ohms
Microphone impedance/connector: 4-pin
Manufactured: Japan, 1976-197x (Discontinued)
- le Sam 18 Nov 2017, 16:55
- Sujet: Hy-Gain 12 (1292) (Portable)
- Vues: 495
Hy-Gain 11 (1291) (Portable)
[Vous devez être [Vous devez être inscrit et connecté pour voir ce lien] et [Vous devez être inscrit et connecté pour voir ce lien] pour voir cette image] [Vous devez être [Vous devez être inscrit et connecté pour voir ce lien] et [Vous devez être inscrit et connecté pour voir ce lien] pour voir cette image]
Canaux: 3
Puissance: 1 W
IF: 455 KHz
- le Sam 18 Nov 2017, 16:49
- Sujet: Hy-Gain 11 (1291) (Portable)
- Vues: 493
Hy-Gain VII (3087) (Base)
Canaux: 80
Puissance: 10 W
Voltage: 13.8VDC or Mains
Manufactured: 19xx-19xx
- le Lun 26 Juin 2017, 03:31
- Sujet: Hy-Gain VII (3087) (Base)
- Vues: 640
Page 1 sur 3 • 1, 2, 3
Aujourd'hui à 22:26 par WarGames58
Aujourd'hui à 21:43 par 14GEF027*
» Zodiac B-4040 (Mobile)
Aujourd'hui à 21:40 par Dundee33
Aujourd'hui à 21:39 par Dundee33
Aujourd'hui à 21:35 par Dundee33
Aujourd'hui à 19:21 par bernard69
Aujourd'hui à 17:23 par Dundee33
» Retevis MB62 (Mobile)
Aujourd'hui à 16:45 par Dundee33
Aujourd'hui à 16:18 par Philoudubroussan
Aujourd'hui à 15:58 par Dundee33
Aujourd'hui à 15:41 par Dundee33
Hier à 21:49 par Dundee33
Hier à 21:36 par Dundee33
Hier à 21:34 par Dundee33
Hier à 20:54 par Phil57
Hier à 20:05 par WarGames58
Hier à 14:46 par Dundee33
Hier à 08:09 par Dundee33
