La date/heure actuelle est Ven 19 Avr 2024, 19:35
1 résultat trouvé pour AT-5555N
AnyTone AT-5555N (Mobile)
(Poste R.A. vendu aux Cibistes)Frequency range: 25.615-30.105 MHz
Channels/tuning steps: 100 Hz
1 / 10 / 100 KHz / 1 MHz
Mode: AM/FM/SSB
RF output power: AM: 12 W
FM: 30 W
SSB: 30 W (PEP)
- Frequency control: PLL
Power supply: 13.8 VDC
TX: Max 7 A
Dimensions (W*H*D): 200*60*283 mm (7.87*2.36*11.14")
Weight: 1.75 Kg (3.86 lbs)
Other features: 6 memories, Instant ch9/19 button, Scanning, Dual watch, ANL/NB,
ASC, CTCSS/PL, DCS, Roger beep, Echo chamber, SWR-meter,
Multi color backlite, PC-programmable
1st IF: 10.695 MHz
2nd IF: 455 KHz
Sensitivity: AM: 1 uV (10 dB S+N/N)
FM: 0.3 uV (12 dB SINAD)
SSB:0.25 uV (10 dB S+N/N)
Selectivity: AM/FM: 6 KHz (-6 dB), 18 KHz (-60 dB)
SSB: 4.2 KHz (-6 dB), 8.5 KHz (-60 dB)
Image rejection: 65 dB
AF output power/speaker: 2 W at 10% distortion / 8 ohms
External speaker connector: 3.5 mm, 8 ohms
Max FM deviation: ±5 KHz
Spurious emissions: Less than -50 dB
Source: http://www.rigpix.com/cbfreeband/cbfreebandselect.htm
Le logiciel: https://laplanetecibifrsoftware.myqnapcloud.com/share.cgi?ssid=0LzXWML
#AnyTone #AT-5555N
- le Mer 10 Aoû 2016, 18:08
- Sujet: AnyTone AT-5555N (Mobile)
- Réponses: 52
- Vues: 5367
Aujourd'hui à 18:20 par 14GEF027
Aujourd'hui à 17:59 par PAPA FOX
