La date/heure actuelle est Ven 19 Avr 2024, 15:06
3 résultats trouvés pour CX-4400
Connex CX-4400 (Mobile)
Canaux: 320
Puissance: 7W
- le Dim 20 Aoû 2017, 05:34
- Sujet: Connex CX-4400 (Mobile)
- Vues: 547
Connex CX-4400 Turbo (Mobile)
(Poste R.A. vendu aux Cibistes)10 Meter Mobile Amateur Radio
AM/FM/PA
100+ Watts
Small Meter with Scales for Signal Strength and Power Output
Front Panel 4 Pin Mic Jack
Blue Channel LED's
- Rear Frequency Counter Jack
Vol, Sql, Mic Gain, RF Gain
Dual Echo and Talk Back with On/Off Switch
Band Selector (8 Bands)
Variable Power Control
ANL-NB or OFF Switch
Blue Lighting for Meter
RX/TX Indicator LED
Specifications:
General:
Model: CX-4400TURBO
Frequency Range: 28.015 to 28.585 MHz
Emission: AM/FM
Frequency Control: Phase-Lock-Loop (PLL) Synthesizer
Frequency Stability: 0.001%
Temperature Range: 0C to +50C
Antenna Impedance: 50 Ohms
Antenna Connectors: Standard SO-239 type
Input Voltage: 13.8V DC
Size: 2-3/8" (H) x 7-7/8" (W) x 10-3/4" (D)
Weight: 5 lb.
Meter: Illuminated; indicates relative output power, received signal strength
Transmitter:
RF Power Output: AM: 50W; FM: 100W
Spurious Emission: -50 dB
Audio Distortion: 10%
Frequency Response: 300 to 2500 Hz
Microphone: Plug-in dynamic; with push-to-talk switch and coiled cord
Receiver:
Sensitivity for 10 dB (S+N)/N: AM: 0.5 uV
Sensitivity for 12 dB (S+N)/N: FM: 0.25 uV
Squelch Sensitivity: 0.5 uV
Selectivity: > -50 dB
Image Rejection: more than -50 dB
Hum & Noise: 40 dB
Audio Power Output: 2.5W @ 10% THD
Contents:
10 Meter Connex CX-4400TURBO Radio
4 Pin Stock Microphone
DC Power Cord
Mounting Bracket with Hardware
Microphone Hanger with Hardware
User's Manual
UPC 0705105786094
Color: Black
Source USA: https://www.bobscb.com/shop/category/TMM0/10-Meter-Mobile-Amateur-Radios/1.html
#Connex #CX-4400 #Turbo
- le Dim 30 Avr 2017, 19:45
- Rechercher dans: Connex | Crystal
- Sujet: Connex CX-4400 Turbo (Mobile)
- Vues: 1215
Canaux: 320
Modes: AM,FM
Puissance: 150 Watts +
- Channel LED's and Meter Light
Vol,sq,mic gain,RF gain
Dual echo
Variable talk back control
PA
4 pin mic wiring
- le Sam 04 Fév 2017, 11:54
- Vues: 618
